Your motherboard support i5 760 or i7 870
You could upgrade to those if you don't want to change your motherboard
I probably shouldn't replace my board right now so I may go ahead and grab that i7 870.
Unless its well worth to buy a motherboard + 2500k (since the cpu is $60 cheaper to)
Yes it is worth to buy a mobo + 2500k rather than buying the 870, as the 2500k is a new one and would be the best around q2 period of the year
Money is semi tight so what would be the overall cost of a new mobo+CPU? Any suggestions?
