BurningSkyline
I'm talking low budget. (like $500-$650 for the tower, $750 max with peripherals.)
Take a look at these Components, I'm curious to see what you Guys think.
Motherboard: MSI P67A-C43 or http://www.newegg.com/Product/Product.aspx?Item=N82E16813130582
Processor: i5-2300 or i5-2400
RAM: G. Skill Ripjaws X Kit- http://www.newegg.com/Product/Product.aspx?Item=N82E16820231443; http://www.newegg.com/Product/Product.aspx?Item=N82E16820231439; http://www.newegg.com/Product/Product.aspx?Item=N82E16820231444
PSU: http://www.newegg.com/Product/Produ...&cm_re=Seasonic_M12II-_-17-151-095-_-Product; http://www.newegg.com/Product/Product.aspx?Item=N82E16817151096&Tpk=Seasonic S12II 620
Video Card: GTX 560 Ti, GTX 550 Ti, HD 6870, HD 6850. I just want to use High settings at 1680x1050, Maybe Max. I could probably get away with a HD 5670.
HDD/SSD: ?
Optical Drive: Something Cheap.
Case: HAF 912, CM690 II, NZXT M59 (Window). Open to any suggestion.
I know this will be near Impossible with my budget, but I bet I can make it happen. I appreciate all Help, suggestions, etc. Thanks everyone. (In advance)
HDD/SSD: ?
