Depends on how good you are at modding and what your expectations are.I want to either mod my current case to improve cable management, or get a new one what do you think?
Specs are in the description.
You can use zip ties for better cable management.You can run the 8-pin motherboard cable from behind.
You can also use tapes.
Antec 300 is not a great case i terms of cable management.
Try to run all the extra cables from behind.
As for mod you can checkout other peoples mod through google and see which one will suit your needs the best.
But I advice against putting a glass window ore anything.
Which is the 8 pin mobo cable? I thought it was a 20 or 24 pin cable.
Or if you can then something like this.
I'm not sure about mounting my HDD backwards I won't be able to power them if I do that. Is this your case? did you mod it?
the issue is I would have to use 2 cables one for my HDD mounted backwards and one for my dvd drive mounted forwards.
I wont mod my case because I don't trust myself with a dremel. I might paint the inside of the case some other day. I have to look into it because apparently not all paint works.This was exactly what I was talking about.This would solve all you cable management problems.
It is upto you now whether you want to do it or not.
Also while you are at it also paint the interior of the case matte black which would totally awesome.
I'll stick with this for now and get a new case further done the line.
Should I get an extension cable for my 12v connection and the 24 pin connector?
