what laptop is better?
skinkipatta
i am going to buy a new laptop for around 939 € i live in i found 2 laptops which one do you think i should buy?
ASUS K72JT-TY093V(around 751,09 €) or ASUS K52JT-SX011V(around 815,47 €)
or can you recommend me another laptop of r around 939 €?
I am looking for a laptop which i can use for gaming.. but not way too expensive :confused::confused:
can't find a website in english showing the specs of Asus K72JT
so the link i put up there is danish.. but u should be able to see what the specs are :D
because i were told from a friend, that that one had SDRAM and the other didn't, and then the one not with SDRAM should be better, but my friend wasn't really sure about this?
Both have plenty of memory, what I was focusing on is the fact they are just about the same but the one I provided uses the i7 processor and that is what I would recommend for some heavy performance.
this is a new laptop i found..
you think i should buy this for gaming?`
Model Packard Bell TS11-HR 530NC Black
Processor 2.3 GHz Intel Core i5-2410
Memory 8 GB DDR3 RAM
Hard Drive 750 GB 5400 RPM
Screen Size 15.6 "Slim LED Glare
Resolution 1366 x 768 pixels
Graphics nVidia GeForce GT540M with 2 GB of dedicated video memory
Drive SuperMulti 8X SATA DVD Burner
Wireless networking Yes, Wifi and Bluetooth
Network 10/100Mbps
Ports 3 x USB2.0 / VGA / HDMI
Card Reader Yes, 5-in-1
WebCam Yes, 1.3 megapixels
OS Windows 7 Home Basic
Applications Adobe Photoshop Elements 8
Weight 2.65 kg.
Dimensions (WxDxH) 38.1 x 25.3 x 3.4 cm
Battery 6 Cells
That laptop would work fine for gaming. You may want to look into getting a anytime upgrade to home premium though. Seems that it may have more of the often used windows features in it.
ok i'll order it.. just another question, when you need a computer for gaming, what should you search for ?? what specifications?
that sounds like a winner to me. 8GB ram. woohaa. that is just fantastic. fo most things we do nowadays. even 4 is more or less enough. but 8. that is just awful nice. can you give me a link? price whereabouts?
