Finding a motherboard
Hey guys, im rebuilding my system, new PSU, graphics card, ram and mobo, but i want to keep my current socket 775 CPU.
Problem: I would like a motherboard that can take 1333mhz or more DDR3 and has a 775 CPU socket. So far i have not found one that will go above 1066MHZ without overclocking. I am beggining to arrive at the conclusion that such a board does not exist. Does anyone know of one?
many thanks for your help :)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128496
By the way, looking at your existing set up, the easiest upgrade is graphic card. You've got PCI Express Graphics slot @ x4 speed. So, just stick a new video card will have some improvement.
I don't really recommend you go down the route for old LGA 775 socket. You are just wasting your money.
Thank you so very much for you help, budget limits mean that i have to stick with my current cpu but i shall be using the motherboard you so kindly found for me and upgrading my graphics card to this:
http://www.aria.co.uk/Products/Comp...le+PCI-Express+Graphics+Card+?productId=42371
my PSU to a 750W one and my ram to this:
http://www.aria.co.uk/Products/Comp...Channel+Kit+-++TW3X4G1333C9A+?productId=37150
does anyone know where i can find this model for sale in the UK? lots on sale in the US but they want $70-140 to ship it....
Thanks again for your help
you won't need 750W psu. A good 500W would do.
Don't get GT 430, 5670 is better for the price
http://www.aria.co.uk/Products/Comp...R5+PCI-Express+Graphics+Card+?productId=39374
Can't find the P45 from newegg.
P43 avaiable in uk
http://www.dabs.com/products/gigaby...le&utm_medium=product+search&utm_content=Q200
What is your overall budget?
thanks, i have allready looked at the 5670 but i decided ont he 430 because of its PhysX and CUDA capibilites. thanks for the mobo link
budget is tight, less than 300, more likely 250 for a mobo, ram, psu, graphics card
thank you so much for you help and support, this is by far the best option i have had yet, though i think i shall swap the CPU for this one:
https://www.aria.co.uk/Products/Com...cket+AM3)+Processor+-+Retail+?productId=41580
thanks again for your hard work
