I have decided its time to built a new computer and need some help getting started. I need some advice for a new CPU and motherboard that are slightly overkill for what I currently use them for, which is 2 WOWs same time(maxed settings) as well as a few web browsers and no lag at all. My current setup no longer allows for those basic uses and to run it quick and easy.
Currently running-
Intel core 2 6300 1.87ghz
2gb ram
GeForce 7600GT 256MB
GIGABYTE GA-965P-DS3 LGA 775 Intel P965 Express ATX
500w Power supply
So for starters I will be going Intel, no AMD. Unless I'm wrong I have heard great things about the Intel I5 and I7, but my questions start flying when I need to pick one as there are many options for both. Budget is not too much of a worry but I will not be buying the best out there. Im looking for midline to good.
So which processor do you recommend and why? also which MB would be a great match for the CPU.
Thanks a bunch I really appreciate it.
Currently running-
2gb ram
500w Power supply
