RAM Speed and Blue screen
chisengseng
starting with my computer build:
CPU: Intel Q9550 Quad core @2.83GHz
VGA: ATI Radeon HD 4870 1GB
RAM: DDR2-667 2 x2GB
POWER: 650W
OS: Windows XP SP3 32bit
this problem bothers me for few years; whenever I use my computer for high-grade gaming (FPS mostly), my computer randomly restart / blue screen.
at first I thought it was my graphic card, so I replace it with a 1GB VGA. but sadly, the error still occurs.
recently, I checked my motherboard manual:
Memory support
4 DDR2 DIMMs suport DDR2 1200(OC) / 1066 / 800
could it be the cause of computer failure? unmatched RAM speed?
this problem frustrates me for years, I couldn't figure out the cause of the problem, after I waste the money on replacing the VGA, i feel thwarted.
I was like, "will it be the motherboard bus? bad power supply flow / lack of power? bad plug connection of the component part? overheating?"
and I don't feel like spending hundreds of dollar on computer checkup at bestbuy or anywhere, so I was hoping to get some valuable advise from expert in here.
thank you for any kinds of comment
I'm a little surprised this didn't cause more problems than it has... That very well could be the problem. Try to buy one stick from a local store so it's easy to take back. Put it in the first slot and see if it runs completely, then either go buy another one or take it back and buy from somewhere like newegg (get the 1066, and I would go for 4gbs), or if it doesn't work, take it back.
If that doesn't fix it, it might be a bad PSU.
Lets figure out what is causing your blue screens.
Download BlueScreenView
No installation required.
Unzip downloaded file and double click on BlueScreenView.exe file to run the program.
When scanning is done, go Edit>Select All.
Go File>Save Selected Items, and save the report as BSOD.txt.
Open BSOD.txt in Notepad, copy all content, and paste it into your next reply.
Dump File : Mini052211-01.dmp
Crash Time : 5/22/2011 8:58:36 PM
Bug Check String : KERNEL_MODE_EXCEPTION_NOT_HANDLED
Bug Check Code : 0x1000008e
Parameter 1 : 0xc0000005
Parameter 2 : 0xab931f3b
Parameter 3 : 0xa32e670c
Parameter 4 : 0x00000000
Caused By Driver : RtkHDAud.sys
Caused By Address : RtkHDAud.sys+75f3b
File Description : Realtek(r) High Definition Audio Function Driver
Product Name : Realtek(r) High Definition Audio Function Driver (HRTF data Copyright 1994 by MIT Media Lab)
Company : Realtek Semiconductor Corp.
File Version : 5.10.0.5898 built by: WinDDK
Processor : 32-bit
Crash Address : RtkHDAud.sys+75f3b
Stack Address 1 : RtkHDAud.sys+2fa2f
Stack Address 2 : portcls.sys+1297d
Stack Address 3 : portcls.sys+129cf
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini052211-01.dmp
Processors Count : 4
Major Version : 15
Minor Version : 2600
Dump File Size : 102,400
Dump File : Mini051711-01.dmp
Crash Time : 5/17/2011 9:27:32 PM
Parameter 2 : 0xab1e0f3b
Parameter 3 : 0xa4f8570c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini051711-01.dmp
Major Version : 15
Dump File : Mini042811-01.dmp
Crash Time : 4/28/2011 11:11:07 AM
Parameter 2 : 0xab272f3b
Parameter 3 : 0xa503670c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini042811-01.dmp
Major Version : 15
Dump File : Mini033111-01.dmp
Crash Time : 3/31/2011 3:13:08 PM
Parameter 2 : 0xac672f3b
Parameter 3 : 0xa64dc70c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini033111-01.dmp
Major Version : 15
Dump File : Mini032611-01.dmp
Crash Time : 3/26/2011 7:13:07 PM
Parameter 2 : 0xac0f0f3b
Parameter 3 : 0xa65d970c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini032611-01.dmp
Major Version : 15
Dump File : Mini020411-02.dmp
Crash Time : 2/5/2011 12:35:18 AM
Parameter 2 : 0xabe64f3b
Parameter 3 : 0xa66a770c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini020411-02.dmp
Major Version : 15
Dump File : Mini020411-01.dmp
Crash Time : 2/4/2011 4:29:34 PM
Parameter 2 : 0xab2e9f3b
Parameter 3 : 0xa640d70c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini020411-01.dmp
Major Version : 15
Dump File : Mini012311-01.dmp
Crash Time : 1/23/2011 6:39:41 PM
Parameter 2 : 0xabba4f3b
Parameter 3 : 0xba1e770c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini012311-01.dmp
Major Version : 15
Dump File : Mini121910-01.dmp
Crash Time : 12/20/2010 12:56:30 AM
Parameter 2 : 0xace1bf3b
Parameter 3 : 0xa704b70c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini121910-01.dmp
Major Version : 15
Dump File : Mini110110-01.dmp
Crash Time : 11/1/2010 11:59:24 PM
Parameter 2 : 0xacde6f3b
Parameter 3 : 0xa03c170c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini110110-01.dmp
Major Version : 15
Dump File : Mini102110-01.dmp
Crash Time : 10/21/2010 2:05:26 PM
Parameter 2 : 0xac790f3b
Parameter 3 : 0xa5c7970c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini102110-01.dmp
Major Version : 15
Dump File : Mini101310-01.dmp
Crash Time : 10/13/2010 6:09:42 PM
Parameter 2 : 0xac179f3b
Parameter 3 : 0xa777c70c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini101310-01.dmp
Major Version : 15
Dump File : Mini091710-01.dmp
Crash Time : 9/17/2010 8:53:47 AM
Bug Check String : UNEXPECTED_KERNEL_MODE_TRAP
Bug Check Code : 0x0000007f
Parameter 1 : 0x00000000
Parameter 2 : 0x00000000
Parameter 3 : 0x00000000
Caused By Driver : EagleNT.sys
Caused By Address : EagleNT.sys+4f28
File Description :
Product Name :
Company :
File Version :
Processor : 32-bit
Crash Address : ntoskrnl.exe+22f1e
Stack Address 1 : ntoskrnl.exe+cb6c3
Stack Address 2 : ntoskrnl.exe+6b254
Stack Address 3 : EagleNT.sys+4f28
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini091710-01.dmp
Major Version : 15
Dump File : Mini091510-01.dmp
Crash Time : 9/15/2010 9:10:25 PM
Parameter 2 : 0xabbb9f3b
Parameter 3 : 0xba2d770c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini091510-01.dmp
Major Version : 15
Dump File : Mini082810-01.dmp
Crash Time : 8/28/2010 11:55:46 PM
Parameter 2 : 0xace39f3b
Parameter 3 : 0xa6f8e70c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini082810-01.dmp
Major Version : 15
Dump File : Mini081510-01.dmp
Crash Time : 8/15/2010 11:37:32 PM
Bug Check String : DRIVER_UNLOADED_WITHOUT_CANCELLING_PENDING_OPERATIONS
Bug Check Code : 0x100000ce
Parameter 1 : 0xa612dbd0
Parameter 2 : 0x00000008
Parameter 3 : 0xa612dbd0
Caused By Driver :
Caused By Address :
File Description :
Product Name :
Company :
File Version :
Processor : 32-bit
Crash Address :
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini081510-01.dmp
Major Version : 15
Dump File : Mini080910-01.dmp
Crash Time : 8/9/2010 9:12:48 AM
Parameter 1 : 0xa76aaf70
Parameter 3 : 0xa76aaf70
Caused By Driver : mouclass.sys
Caused By Address : mouclass.sys+354
File Description : Mouse Class Driver
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 5.1.2600.5512 (xpsp.080413-2108)
Processor : 32-bit
Crash Address :
Stack Address 1 : mouclass.sys+354
Stack Address 2 : ntoskrnl.exe+1a605
Stack Address 3 : ntoskrnl.exe+9fb9e
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini080910-01.dmp
Major Version : 15
Dump File : Mini080610-01.dmp
Crash Time : 8/6/2010 11:42:01 PM
Parameter 2 : 0xac707f3b
Parameter 3 : 0xa261d70c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini080610-01.dmp
Major Version : 15
Dump File : Mini071810-01.dmp
Crash Time : 7/18/2010 11:45:33 PM
Parameter 2 : 0xac76cf3b
Parameter 3 : 0xa830670c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini071810-01.dmp
Major Version : 15
Dump File : Mini071610-01.dmp
Crash Time : 7/16/2010 5:58:44 PM
Parameter 2 : 0xac63ef3b
Parameter 3 : 0xa887c70c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini071610-01.dmp
Major Version : 15
Dump File : Mini063010-01.dmp
Crash Time : 6/30/2010 3:16:33 PM
Parameter 2 : 0xac825f3b
Parameter 3 : 0xa825770c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini063010-01.dmp
Major Version : 15
Dump File : Mini062710-01.dmp
Crash Time : 6/27/2010 6:46:31 PM
Parameter 2 : 0xac748f3b
Parameter 3 : 0xa983970c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini062710-01.dmp
Major Version : 15
Dump File : Mini062410-01.dmp
Crash Time : 6/24/2010 6:54:45 PM
Parameter 2 : 0xac28ef3b
Parameter 3 : 0xa7cc770c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini062410-01.dmp
Major Version : 15
Dump File : Mini062110-01.dmp
Crash Time : 6/21/2010 5:44:07 PM
Parameter 2 : 0xab3c0f3b
Parameter 3 : 0xa724470c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini062110-01.dmp
Major Version : 15
Dump File : Mini062010-01.dmp
Crash Time : 6/20/2010 9:11:35 PM
Parameter 2 : 0xace95f3b
Parameter 3 : 0xa73c770c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini062010-01.dmp
Major Version : 15
Dump File : Mini061810-01.dmp
Crash Time : 6/18/2010 10:07:20 AM
Parameter 2 : 0xac7a5f3b
Parameter 3 : 0xa8f1570c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini061810-01.dmp
Major Version : 15
Dump File : Mini060310-01.dmp
Crash Time : 6/3/2010 11:20:35 AM
Parameter 2 : 0xac8aff3b
Parameter 3 : 0xa860f70c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini060310-01.dmp
Major Version : 15
Dump File : Mini052610-01.dmp
Crash Time : 5/26/2010 2:25:57 PM
Parameter 2 : 0xaca12f3b
Parameter 3 : 0xa7ae670c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini052610-01.dmp
Major Version : 15
Dump File : Mini051610-01.dmp
Crash Time : 5/16/2010 11:38:10 PM
Parameter 2 : 0xac6e8f3b
Parameter 3 : 0xa354770c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini051610-01.dmp
Major Version : 15
Dump File : Mini042910-01.dmp
Crash Time : 4/29/2010 6:04:05 PM
Parameter 2 : 0xac602f3b
Parameter 3 : 0xa86d170c
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini042910-01.dmp
Major Version : 15
Dump File : Mini012310-01.dmp
Crash Time : 1/23/2010 11:54:17 AM
Caused By Driver : ati2cqag.dll
Caused By Address : ati2cqag.dll+49346
File Description : Central Memory Manager / Queue Server Module
Product Name : ATI Radeon Family
Company : ATI Technologies Inc.
File Version : 6.14.10.0432
Processor : 32-bit
Stack Address 1 : ntoskrnl.exe+cb6e1
Stack Address 2 : ntoskrnl.exe+6b234
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini012310-01.dmp
Major Version : 15
Dump File : Mini122909-02.dmp
Crash Time : 12/29/2009 4:42:45 PM
Caused By Driver : atikvmag.dll
Caused By Address : atikvmag.dll+40926
File Description : Virtual Command And Memory Manager
Product Name : Virtual Command And Memory Manager
File Version : 6.14.10.0106
Processor : 32-bit
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini122909-02.dmp
Major Version : 15
Dump File : Mini122909-01.dmp
Crash Time : 12/29/2009 4:36:50 PM
Processor : 32-bit
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini122909-01.dmp
Major Version : 15
Dump File : Mini111009-01.dmp
Crash Time : 11/10/2009 8:59:52 AM
Processor : 32-bit
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini111009-01.dmp
Major Version : 15
Dump File : Mini083009-01.dmp
Crash Time : 8/30/2009 8:09:56 AM
Processor : 32-bit
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini083009-01.dmp
Major Version : 15
Dump File : Mini081809-01.dmp
Crash Time : 8/18/2009 8:12:16 PM
Processor : 32-bit
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini081809-01.dmp
Major Version : 15
Dump File : Mini080609-01.dmp
Crash Time : 8/6/2009 2:14:32 PM
Processor : 32-bit
Crash Address : ntoskrnl.exe+22f0e
Stack Address 2 : ntoskrnl.exe+6b224
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini080609-01.dmp
Major Version : 15
Dump File Size : 94,208
Dump File : Mini072709-03.dmp
Crash Time : 7/27/2009 7:24:51 PM
Processor : 32-bit
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini072709-03.dmp
Major Version : 15
Dump File : Mini072709-02.dmp
Crash Time : 7/27/2009 6:29:04 PM
Processor : 32-bit
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini072709-02.dmp
Major Version : 15
Dump File : Mini072709-01.dmp
Crash Time : 7/27/2009 6:20:23 PM
Processor : 32-bit
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini072709-01.dmp
Major Version : 15
quite a long list:eek:
Your blue screens are caused by your audio driver, it seems it may be way out of date. Please visit msi website to download the lastest audio driver for your motherboard.
so my unmatched RAM has no impact to my system?
that's kind of weird:confused:
I used the MSI update scan, and here's the result:
MB Driver Intel INF UPdate
VGA Driver ATI
MSI Utility Super-Charger
MSI Utility Teaming Genie
MSI Utility Video Genie
Other Utility Esobi
Other Utility Mufin Player
Other Utility Norton Internet Security
Other Utility Norton Online backup
Other Utility Splashtop Connect
Other Utility Video Easy SE
Other Utility Media Espresso
Other Utility Power2GO
which one should I update :confused:
Edit:
oh I found it using manual search on their website
thanks
