Budget Builld (Need Help)
Canadian
I have found these parts for a budget build. I have some questions about the build because I'm having trouble (I only have some parts for this build cause the rest I have at home):
RAM: http://www.canadacomputers.com/product_info.php?cPath=24_311_312_611&item_id=037782
Processor: http://www.canadacomputers.com/product_info.php?cPath=4_64&item_id=031942
Motherboard: http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=7144823&CatId=4296
Case: http://www.canadacomputers.com/product_info.php?cPath=6_112&item_id=027049
Video Card: http://www.canadacomputers.com/product_info.php?cPath=43_557_558&item_id=027869
Is there a better Video Card I can get at a cheaper price?
What type of Power Supply do I need? (How many watts?)
Does everything fit into the case and onto the motherboard?
Thank you so much in advance.
should work but unless gaming gpu is unnecessary, and if you are then it won't gett you very for if you want good res or shading but otherwise it'll be fine on low settings
Is there any other good budget Video Card around $50-$90 that would make gameplay good at a higher resolution and shading?
Whats the top end on your budget your wanting to spend?
what exact resolution do you want, cuz at 1900x1200 or whatever it is, and with all settings on high, you'd need a gtx 570 or higher, or radeon hd 6950 or higher, and those are all hundredSSS for it alone, and a cpu that'll keep up with it will be 200 and a psu good enough for it'll be another 70, you may be able to mir a little off that but no more than like 50 total
Sorry i took a while to respond
My highest budget is about $350
The resolution I would like is a average suitable one like 1024x678 going at least 50-60 on games like GTA or BF2 or MW2 but I mostly play League of legends and MW1
are you planning on using the power supply hard drive and os off an old computer or something cuz you don't have those ther and tha'll be like 180 alone then there's all the mobo cpu gpu and ram too then a case to put it in.
what's the power supply, as this most likely needs to be tossed for this build since ones that come with the computer are crap and not high enough power for a gpu always, what's the harddrive so i know what board i can get for the socket type, and i've been told the os may not be able to use as it is tied to the motherboard or something
The powersupply I have is a 300 Watt that I wasn't sure of getting cause it might crash everything. The hard drive is Seagate 3.5" 156 GB with windows XP
the power supply need more watts and you might want to get a secondary hdd cuz that won't hold too much, but that won't cost much, i'll put something together
strangle, or anyone else that knows what they are talking about, do ya'll think a llano would be good for him in this case, and allows for a gpu later on but the integrated is more powerfull than that one he listed i think.
i didn't pick a cas for you cuz it's personal liking, but here are some, and the second is the nicest to me and after mir will put you almost in budget, might be a couple over the 350, but if you order the case first, every time i've ordered from them about 2-3 days later i get an email with a ton of cupons that you can use to pull the price down more, or post a pick or send it to me to prevent problems with steeling the cupon codes, and i can revise it to save more money, but here are the cases i liked then after are the parts
http://www.newegg.ca/Product/Produc...33-094^11-133-094-TS,11-156-223^11-156-223-TS
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136073
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820220559
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128516
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103942
i was talking about llano's integrated gpu, known as the 6550D, which rivals a 70 dollar gpu, so i think it'll beat yours listed.
anything with pci-e x16 works together, the 2.0/1 are revsions that are backwards compatible with the others, did you see the list that i posted as it is more powerful and will do you much better than those.
