No files will work except
Download this zipped file and unzip it then double click on it to run it to fix the registry entries.
http://www.dougknox.com/xp/fileassoc/xp_exe_fix.zip
Afterwards, you should be able to run exe files. Then do the following to scan your system for malware.
  • then click Finish.
If for some reason Malwarebytes will not install or run please download and run Rkill.scr, Rkill.exe, or Rkill.com but DO NOT reboot the system and then try installing or running Malwarebytes. If Rkill (which is a black box) appears and then disappears right away or you get a message saying rkill is infected, keep trying to run rkill until it over powers the infection and temporarily kills it. Once a log appears on the screen, you can try running malwarebytes or downloading other programs.
Sorry, that can't be done. Do me a favor, boot to safe mode with networking by restarting your system and press f8 to get the safe mode menu to appear highlight safe mode with networking and hit enter. See if you can run programs in there. If so do the following.
So how did you get into windows now? How long as it been making this beeping? Sounds like you have a memory issue. Remove and reinsert the memory and see if it boots up correctly.
I need you to reboot in safe mode and see if it will allow you run programs. If the laptop won't reboot without beeping then you need to figure that out first and then we can deal with it not running programs.
Are you able to run programs in safe mode? If you plan on reinstalling, then stay with XP. If you are able to run programs in safe mode then most likely you are infected and you should run the programs that i have asked you to run and post the logs.
You need to have someone back up any important data and reinstall windows XP. Afterwards, all the appropriate drivers will need to be installed.
Do you have any data on your drive that you need saved before you reinstall windows fresh? To do a fresh install of windows means all data will be erased. If you have the XP install cd then you just boot to the cd follow the instructions and delete the existing partition or partitions and then repartition and install windows. Here is a guide with screen shots.
http://pcsupport.about.com/od/operatingsystems/ss/instxpclean1.htm
