need advice on speakers
ICMB
recently my speakers and my gaming headset have broken
I cannot decide what I want to get a headset or speakers. In all honesty I would rather get speakers but I do not want to spend copious amounts of money boy i'm willing to use some money but I would like some left over money for a decent cpu cooler.
I have about 200 - 220 $ to spend
how good of speakers do you want you can probably get a decent sounding set of speakers (2.1) for like $50
a good 2.0 set is the Creative GigaWorks T40 series II, i'm looking at getting them. They're around $120 here in Aus and have good sound for the price. They're a 2.0 set, so the bass isn't as good as with a subwoofer, but if you don't have room then they're good
might get some of them then. Even though they're more expensive, they seem good.
But would we need a sound card, or would onboard be just fine? Otherwise, all the reviews look good
Try it without a sound card, and if you're not satisfied then try it with a good sound card. I'm running them with a Xonar D1 and they sound great.
what is the diff with 2.0 2.1 and 5.1? which is best for gaming?
The number before the period represent number of speakers. The number after the period represents the number of subwoofers. Thus 2.0 speakers have 2 speakers and no subwoofer. 5.1 speakers have 5 speakers and a subwoofer.
For gaming generally 5.1 speakers are best. For music 2.0 or 2.1 systems better.
For $120 you might as well pick up some used ATH-AD700's like I did. They are great for music and gaming.
