C4Radon
Planning on building a new computer soon, I kind of threw this build together in a hurry and want to know what you guys think. Any compatibility issues? Recommendations on parts? One part I'm not sure on is the sound card. I'm just tried of being held back by it as my headphones are quite high end I wanted to go all out on the sound card.(Relative to what I'd usually spend on one) Any help would be appreciated. Any I'm big on keeping my computer as cool as possible, and recommendations on fans would be a big help. (120 mm fans). As well as a heatsink, is the one I chose reliable/effective? I would like a recommendation or your thoughts on it.
__________________________________________________________
PSU: CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
Link:http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
MOBO: ASUS P8P67 PRO (REV 3.1) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Link:http://www.newegg.com/Product/Product.aspx?Item=N82E16813131771
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8D-8GBXM
Link:http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
Hard Drive: Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Link:http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Dvd Drive: ASUS Black 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive Model BC-12B1ST/BLK/B/AS
Link:http://www.newegg.com/Product/Product.aspx?Item=N82E16827135247
GPU: EVGA 012-P3-1571-KR GeForce GTX 570 HD w/Display-Port (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Link:http://www.newegg.com/Product/Product.aspx?Item=N82E16814130613
CPU: Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
Link:http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Case: IN WIN Dragon Rider Black 1.0 - 0.8mm SECC Steel ATX Full Tower Computer Case
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16811108376
Monitor: Asus VE248H Black 24" 1920X1080 2ms Full HD HDMI LED Backlight LCD Monitor w/Speakers 250 cd/m2 10,000,000:1
Link:http://www.newegg.com/Product/Product.aspx?Item=N82E16824236102
Total Price: ~$1500 (Shipping included)(Rebates not yet included)
Thankyou again... I don't want to spend any more than around 1850 on this, so if you recommend I upgrade one part if it goes over 1850, maybe make a recommendation on another part that should/can be downgraded. Eg: "upgrade graphics card to [?] and downgrade your cpu to [?]. Something along those lines."
Thankyou!
EDIT: Changed the PSU, RAM, harddrive, and deleted soundcard, option of heatsink also eliminated. Case has also been changed. I just switched out the i7 2600k sandy bridge for a i5 2500k sandy bridge as the price difference is over 100 dollars and the change in performance isn't drastic. I'm now trying to cut back on price a little due to certain issues that recently came up. I also switched out the ASUS MAXIMUS IV EXTREME with a much cheaper and still very good ASUS P8P67 Pro. It also took around $150 additional dollars off the cost.
Rough price also changed
Thankyou!
