Battlefield 3 Thread
diduknowthat
formerly liuliuboy
Im not sure if i should get my battlefield on pc, xbox, or ps3. From what i have noticed, joining multiplayer matches are easier on consoles than on the pc. when i play pc games and i join a server the server usually has some weird mod on it.
Although its probably going to look fantastic on my pc.
Any suggestions?
PC version is going to have better graphics and 64 player multiplexer support (vs 24 players for console. You should totally try to get the PC version if your computer can handle it.
Sdot
If you have a decent enough spec of pc then i would get it for PC as they are focusing more on the PC version and it wil be allot better.
I have an I7 920, 4850X2, 6 gigs of ram, etc. I built this in 2009. Do you think this will be good enough or do I need to make improvements?
I think I want to do a nice triple monitor setup to play this game, also I want to try to play it with those new razor hydras cause it looks fun. What do you think?
Shane
Super Moderator
Your system will be able to handle it fine,Although id recommend upgrading the graphics card if you can afford it for some DX11.
Sdot
Oh okay, which card do you suggest, one of those eyefinity ones so I can do the triple monitor easier? Also what do you think of the razor hydras?
mihir
First your PSU model/specs and Brand and then a suggestion on GPU,although with your current config I would say no need to get a GPU now you can easily wait till the next GPU series. :D
salvage-this
IMHO the 4950x2 probably still kicks the crap out of games. DX11 is nice to have but Not worth the upgrade if you have a GPU like that.
Aastii
I agree completely, there is absolutely no reason to upgrade anything. If it turns out the game needs higher specs, then go for it, but I wouldn't get it now, I would wait, firstly to be certain you actually need it, and secondly because prices will have probably dropped by that time
Sdot
alright thank you, oh and did you see what i said about the razer hydras? I just wanted you guys opinion on it.
Aastii
absolutely pointless :)
You would be at a huge disadvantage in games. It may add to immersion, but try playing against people with a mouse and keyboard when you have a wiimote. That is what it would be like. You won't be able to turn as fast, you won't be able to aim as precisely, buttons won't feel as natural as wasd and mouse does. you are at a disadvantage if you play FPS games on PC with a gamepad, that controller would make it a hell of a lot worse than that
The only gadget I would ever recommend for FPS gaming is TrackIR, though it is only any use if they implement it into the game, and if you are able to move your FOV independent to your movement. Basically, if you can turn your head but not your body in game, it would be worth it
http://www.naturalpoint.com/trackir/
Sdot
yeah your right, thank you for your input.
mihir
http://www.youtube.com/profile?user...nnotation_875820&feature=iv#p/u/1/0djf23itXAA
Guy list recommenced specs in the description, no idea if it's accurate though.
Those specs are not official,they are based on his personal experience with computers.
He has written Predicted Specs.
But anyways his recommended specs are way to high.
BF3 Alpha is an easy 9/10 for me. I HIGHLY recommend you preorder the full game.
WILL YOUR GAMING PC RUN BATTLEFIELD 3?!
Predicted System Requirements (Based on Tests):
Quad Core Processor (min Dual Core 2.0Ghz)
4GB Ram (min 2 GB)
GTX460 or HD6850 (min 512MB GFX Memory)
With the recommended System you WILL get 60fps at 1280x720 and around 30fps at 1920x1080p.
As a reference the Alpha plays at the same sorts of frames as Crysis 2 does in dx9. Frame rates are ~10 less than in Bad Company 2 on average.
REMEMBER THIS IS THE ALPHA THE FULL GAME WILL HAVE BETTER GRAPHICS AND BE BETTER OPTIMISED.
Recommended Gaming PC Build: i7 950, 6GB RAM, gtx560ti (will get ~40-50fps max settings 1080p [predicted]).
Do not quote me, I am only making suggestions from my experience
russb
Is that right 60fps at 1280x720 and around 30fps at 1920x1080p so if i set my res lower i get better fps.:)
NyxCharon
Yeah, i figured as much, but there a decent guideline to follow for now. And yea, i agree, the recommended are way to high to be right. Luckily, i fall somewhere in between, so i should be good to go. :good:
Shane
Super Moderator
I cant believe the amount of people sharing info and screenshots/Vids on BF3 Alpha....did they forget we are bound by NDA. :/
