Will this build work?
abraham3660
I am doing my first pc build and looking for some advice. This is an extreme budget build, so trying to keep it around $500 with windows. Here are my parts. I know the graphics card is not the best. Will it run games like hon, lol, and dota 2 (when it comes out) with no problem? Is there a better one for around the same price? Also how much power do i need? Will this be okay even if i wanted to put some leds in the case, or an extra fan? Thank You for any help.
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
Board: http://www.newegg.com/Product/Product.aspx?Item=N82E16813138283
Graphics Card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814500147
Power: http://www.newegg.com/Product/Product.aspx?Item=N82E16817152028
Processor: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103873
Memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820226095
Hard Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218 Edit: Changed to internal
Drive/Burner: http://www.newegg.com/Product/Product.aspx?Item=N82E16827136238
Why an external hard drive? Also, do you have to buy a monitor + mouse + keyboard? Because in that case, it won't be just 500$... Just those components you listed+ shipping + taxes = about 450$. So if you have to buy, let's say, windows 7 premium 64 bit OEM (about 100$), plus a lcd screen (about 100$), plus a good keyboard and a good mouse (about 30$), including taxes and shipping, your WHOLE computer could very well cost you 700$...
Yes i already have a mouse and keyboard and I am looking for a monitor now. I just want to know if this is a good budget build.
look on neweggs latest email special on the home page, they had some recertified monitors.
and that builds just gunna stink, ill put something together, but there are many problems with that.
These should be changed, along with some recommends for the rest.
If you go a little more than $500 and do a couple rebates ($40), the difference would be huge.
here's the components, and these are way better than yours listed, and the mobo allows for the next generation of amd cpu's coming out later this year, but they begin around 200 so no point in waiting unless you save up another couple hundred so it's worth it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131767
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125391
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.679951
