abraham3660
I am doing my first pc build and looking for some advice. This is an extreme budget build, so trying to keep it around $500 with windows. Here are my parts. I know the graphics card is not the best. Will it run games like hon, lol, and dota 2 (when it comes out) with no problem? Is there a better one for around the same price? Also how much power do i need? Will this be okay even if i wanted to put some leds in the case, or an extra fan? Thank You for any help.
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
Board: http://www.newegg.com/Product/Product.aspx?Item=N82E16813138283
Graphics Card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814500147
Power: http://www.newegg.com/Product/Product.aspx?Item=N82E16817152028
Processor: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103873
Memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820226095
Hard Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218 Edit: Changed to internal
Drive/Burner: http://www.newegg.com/Product/Product.aspx?Item=N82E16827136238
