Need help with case :( :O!
512mb
Hey all,
I need help once again :(. I am looking for a new cpu case, and I have been for a while now :(.. However I need a case that has great cable management***, cooling cooling cooling!!!!
Thanks,
512mb
we don't allow users to offer rewards for replying to their threads. I've removed that bit from your OP.
I took the $300 drop in the wallet and invested in a Corsair Obsidian 800D. Looks great. I thought it was worth it. But to others, maybe not so much. Great cable management. Great air flow management. Love it.
Yeah I've seen it and it is a great case, but it is way to expensive for me I know and probably for some others too.
I like the look of the NZXT Phantom (Black and Green edition), it looks really badass.
Yeah I love it. I got the Newegg Exclusive Black with Orange trim, but the Black with Green looks pretty sweet.
@OP
Have you looked at any other cases you think might be good?
Take a look at the Lanboy Air, people either love it or hate it. I took the chance with it and I'm extremely happy with the airflow and space for cable management. I've always been partial to bottom mounted PSU's but unfortunately the cables on my PSU were a tad short for comfort so I re-arranged it to have the PSU at the top. I also moved the DVD burner all the way to the bottom on the front since I keep my comp on my desk.
One thing I was a bit nervous about was that all the fans on this case point inward to create Positive Pressure which I wasn't to sure about, but when I put my hand next to the case I can actually feel the air coming out pretty strong. My MB temp has never gone above 26ºC and my CPU stays low 30's idle and mid to high 40's under load OC'd at 4GHz.
The 5 stock fans that come with it are enough, and there's room for a total of 15 120mm fans. The potential for custimization is why I bought it, not to mention it looks sweet:cool:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129091
Newegg Unboxing vid- http://www.youtube.com/user/newegg?blend=1&ob=5#p/search/2/8V-fmnBlmtE
Newegg test build 15 fans-http://www.youtube.com/user/newegg?blend=1&ob=5#p/search/1/649kvK9bN6o
Also there's 3 colors to choose from, red/black, blue/black and yellow/black
