jaishankar
My disk cleaner freeware is showing error whenever i use it and click on clean, look at this image
Uninstall it and get rid of it. Use Ccleaner instead.
http://download.cnet.com/ccleaner/
While you are at it, scan your system for malware by doing the following.
- Double-click mbam-setup.exe and follow the prompts to install the program.
- At the end, be sure a checkmark is placed next to
- Update Malwarebytes' Anti-Malware
- and Launch Malwarebytes' Anti-Malware
- then click Finish.
- If an update is found, it will download and install the latest version. Please keep updating until it says you have the latest version.
- Once the program has loaded, select Perform quick scan, then click Scan.
- When the scan is complete, click OK, then Show Results to view the results.
- Be sure that everything is checked, and click Remove Selected.
- A log will be saved automatically which you can access by clicking on the Logs tab within Malwarebytes' Anti-Malware
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
When the hijackthis log appears in a notepad file, click on the edit menu, click select all, then click on the edit menu again and click on copy. Come back to your reply and right click on your mouse and click on paste.
Download malwarebytes and hijackthis and post the logs. Some registry cleaners are actually rogue programs that are not safe to use.
i didn't like malware bytes
