Disk Cleaner problem help me
jaishankar
My disk cleaner freeware is showing error whenever i use it and click on clean, look at this image
Uninstall it and get rid of it. Use Ccleaner instead.
http://download.cnet.com/ccleaner/
While you are at it, scan your system for malware by doing the following.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
When the hijackthis log appears in a notepad file, click on the edit menu, click select all, then click on the edit menu again and click on copy. Come back to your reply and right click on your mouse and click on paste.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
is this all required:(, i had backup of my pc created by hirens boot restored it coz there were few other issues with my os off late now everything is fine
Download malwarebytes and hijackthis and post the logs. Some registry cleaners are actually rogue programs that are not safe to use.
brother john i have already said that i have a backup of my OS, restored it now everything is fine, NE way many many thanks 4 ur help.:good:
