rustynail925
Im looking for a small case
im planning to put maybe 3 hdd and 1dvd rom
any recommendation?
any recommendation?
is it reasonable to invest in a case worth as much as your processor?
If so how long do you guys upgrade or change computer cases?
now im thinking about the Corsair 600T after seeing the video revies.
The only bad thing is that its gonna be heavy and also the size of it.
Or the
Cooler Master Storm Enforcer
Heres my list.
CPU - Intel Core i5 2400 3.1GHz
MB - ASRock H61M/U3S3
RAM - 2x G.Skill RJX 4gb (Dual)
GPU - Sapphire 5850 Extreme 1gb/256bit ddr5
PSU - Antec TruePower New 750Watts
HDD - Seagate 1tb 7200.12
Monitor - 2x Samsung 22"inch
I like the inside of this but dont like the size and weight
Cooler Master 690II advanced
Cooler Master 912 Advanced
NZXT H2
Ideal size and weight
Cooler Master Elite 371 http://www.coolermaster-usa.com/product.php?category_id=19&product_id=3028
why do you say that i wont overclock my machine?
maybe in the future i will overclock it
The manufacturer says its a mid tower, but if you look at the specs, its one of the biggest ones out there. You'd have no trouble moving around in it.I am going to use the Corsair 600T on my next build. It is nice clean looking case which is builder friendly (keeping in mind that it is a mid tower. I am going to get the white edition though, while modifying the viewing window (too small and boring).
I took the corsair carbide 400R very nice case.
