Case recommendation
Thanks. The Corsair 600T is too big. Im lookin for a compact and lightweight one
whats up with the too many ang big fans? What if i will not be using overclock
The HAF series are great cases. Pretty much, you want one that looks good to you, has the amount of space you want, (I like cases that I can buy another one and have a vacation home) and has cable management.
is it reasonable to invest in a case worth as much as your processor?
If so how long do you guys upgrade or change computer cases?
Never.......just repair as needed.
Blow all out once a year and clean, but i don't have the towers on the floor. its on the table.
Heres my list.
CPU - Intel Core i5 2400 3.1GHz
MB - ASRock H61M/U3S3
RAM - 2x G.Skill RJX 4gb (Dual)
GPU - Sapphire 5850 Extreme 1gb/256bit ddr5
PSU - Antec TruePower New 750Watts
HDD - Seagate 1tb 7200.12
Monitor - 2x Samsung 22"inch
I like the inside of this but dont like the size and weight
Cooler Master 690II advanced
Cooler Master 912 Advanced
NZXT H2
Ideal size and weight
Cooler Master Elite 371 http://www.coolermaster-usa.com/product.php?category_id=19&product_id=3028
now im thinking about the Corsair 600T after seeing the video revies.
The only bad thing is that its gonna be heavy and also the size of it.
Or the
Cooler Master Storm Enforcer
The coolermaster 912 is an awesome case, I have it. It's got a dedicated spot for an SSD drive and tons of room for the longer video cards.
Or the
I am going to use the Corsair 600T on my next build. It is nice clean looking case which is builder friendly (keeping in mind that it is a mid tower. I am going to get the white edition though, while modifying the viewing window (too small and boring).
Heres my list.
NZXT H2
Question - Why are you choosing H61 motherboard?
I suggest go for cheap Z68
PSU - You won't need 750W with single 5850. And looking at your set-up, I don't expect you overclock you machine.
All these 3 case should be fine. It down to which outlook you like
The manufacturer says its a mid tower, but if you look at the specs, its one of the biggest ones out there. You'd have no trouble moving around in it.
I took the corsair carbide 400R very nice case.
Nice choice.
