ixiboneheadixi
banned
well im going to guess and say the next new ram will be ddr4, anyone have any info on this yet? and how it will compare to current ddr3
http://en.wikipedia.org/wiki/DDR4_SDRAM said:DDR4 itself is a DRAM interface specification. Its primary benefits compared to DDR3 include a higher range of clock frequencies and data transfer rates (2133–4266 MHz and MT/s compared to DDR3's 800–2133[1][2]) and significantly lower voltage (1.2 decreasing to 1.05 volts,[2] compared to 1.5 – 1.2 V for DDR3). DDR4 also anticipates a change in topology – it discards dual and triple channel approaches in favor of point-to-point where each channel in the memory controller is connected to a single module.[2][3] Switched memory banks are also an anticipated option for servers.[2]
so its pretty much the same thing just faster?
so by what time do you think we can expect motherboards and such that are compatible with ddr4 to be out? with all the knew cpus and gpus coming out in the next year, should i just wait for some ddr4 aswell?
Expect it to start showing up in stores sometime next year. Dual, triple channel should be gone, it will be point to point instead. Other changes are the usual stuff, more bandwidth, less voltage.
