Hi fellas, I was wondering whether one of you guys would be able to help me out with some advice since my comp is acting rather strange.
I've had my pc for around a year and a half and never had any problems with it. A week ago i shut it down normally and when i switched it back on, the fans would spin really fast and nothing else would happen, it would just stay like that until i switched it off manually either via the plug or power button.
I took it to the shop, thinking they were the experts and all, and they said it was just simply dust that found its way between the CPU and motherboard and the two werent able to make proper contact, hence it wouldnt switch on. So they cleaned it for me and it worked normally from then till now...
Today, whilst watching a video on youtube, my mouse just froze so i decided to restart my pc... unfortunately upon restarting it the same problem happened again, the fans would spin really fast and loud and my computer wont switch on. The weirdest thing is this: I took the cpu out checking for dust again but there was none, plugged it back in and it worked fine. I shut it down again, and the same problem, it wont switch on. Took out the cpu again, plugged it back in etc...
So now my pc wont switch on after i shut it down unless i take the cpu out and plug it back in lol...
Any thoughts? Your help would be greatly appreciated (PS sorry for the long text)
