Building New computer
XLCobalt
Ok. This is my first computer build. I am in school for computer engineering, so i would say that i have a pretty good understanding of parts and everything. But i would like some imput from u guys if u dont mind. Here is my parts list.
Case 39.97
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=5520044&Sku=T925-3018
Motherboard $184.97
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=440723
Thermal compound $9.97
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=6470733&CatId=503
Processer $309.97
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=7073159&CatId=6991
RAM 59.97
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=7104116&CatId=4534
HDD $71.99
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=7288051&CatId=139
Network Card 23.99
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1272636&Sku=T156-2114
GPU $73.99
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=675199&CatId=3585
Power Supply $23.99
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=4252524&CatId=1077
DVD Drive
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=6246700&Sku=O451-1017 OEM
Sata
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=4655881&CatId=5444
OS = Free
7 home
My only major concern at this moment is the power supply. I am not sure how many watts i am going to need to run ur setup. My only other concern is installing things. Are most HDD PnP? because how do u install the HDD driver without an OS? or how do u install and OS if ur HDD needs a driver installed?
what will you be doing with this, cuz that build is just way off, better than many people have posted but the cpu is almost guaranteed a waste depending on what ur doing, psu is too, and gpu isn't going too far in games, also have you looked at newegg.com?
i dont see anything wrong with a i7 2600k as far as price goes...now if it was 500 bucks..ok maybe but 300 dollars on a cpu that will last a while through several gpu's possibly, thats a good buy.
I know its a fast Cpu. But i dont mind. I prob wont even need something that fast. But this way i dont have to switch it in a year or 2. As for the PSU i am going to go with the one suggested in the post above. That was the only thing i was not sure about. I was not sure what kind or how much power i needed. Also. What GPU would u suggest. This one should run almost anything i want to play. I have my PS3 for CoD and other games
well the only thing the i7 has over the i5 is it tries to be 8 cores with only 4, it has the information threads of 8 cores but only 4 cores, while the i5 has 4 cores and 4 threads, but only en and decoding and video creation know how to use those cores, and not much else will for a while. if you go to the i5 i'd also say to put that money to a nicer case, cooler master haf's and lian li's are some of the best ones with lower end models. also z68 is only bette than p67 for ssd's and using the intel hd gpu, otherwise the p67 with the same stuff might be a little cheaper and the same for you.
what screen rez do you plan to run at? if you plan to stick around 1920x1080, nothing more than a 560Ti would be needed, anything past, id say a 570 or 580 GTX from nvidia or a radeon 6950 would be a good idea. else, id say a 6870 would be (about?) equivalent to a 560Ti
Z68 offers encoding acceleration using the integrated gpu while using the dedicated card, offers SRT tech for caching as well as having better support for harddrives such as the new 3TB capacity drives. i highly recommend the z68 board for current generation sandy bridge chips due to the SRT tech alone. people will contest this saying you should just grab a bigger ssd and install there, but its a good alternative for people that dont want to spend cash on a huge (abeit small in comparison to mechanical drives) ssd.
and 8 threads CAN be useful, espically if your doing programming or decoding of things, i know VS studio 2010 can use all 8 threads to decode a project at once in parallel, however it will take a ton of ram mind you, but it CAN use those threads, just you would have to have a application for them, elsewise you may want to stick with the i5 series chips if you are trying to save some money.
i said that about en and decoding things and most video software use the 8 cores, but not much else. and for the gpu he only needs that high stuff to be maxing mmo's out at high res, the one he picked will do fine on lower res or do high res with lower details and shading
