Hi Guys,
Ive got a Asus Maximus Extreme motherboard which is failing to boot.
Ive stripped it right down to CPU RAM Gfx Card and Power supply.
On the little LCD Display it shows the code CPU INIT which is the CPU Initialization process in the boot. It shows this whether its trying to start or when the power supply is just turned on and the motherboard isnt.
When i do try to start it up by the onboard power button it will fire up everything for 4 seconds and then switch off for 4 seconds, then turn it self back on for 4 seconds and repeat the process.
Ive tried a Quad 9550 CPU in there and a E2200 Dual core in there which are both supported processors, a 6970 Graphics card and 2GB DDR3 RAM.
Ive tried the Major long CMOS Reset which seems to be a common problem with these boards but that seems to be about a no post beep problem rather than a problem with it shutting off and restarting itself.
Any ideas to try?
Thanks
Any ideas to try?
Thanks
