terminator
My H60 that I just bought is acting very strange, its been between 70 and 100c but once I got it to run at 30c for about ten minuets then it started to rise to 70c(With the radiator fan as intake) so then I shut it off and switched the radiator fan to exhaust. booted it up and it was running at 30c untill I rebooted 40 mins later.... and its running at 98c! so now im pretty much banging my head on the desk. iv'e tried everything to my knowledge. Switching between one fan and push pull, switching between , PWR_FAN, CHA_FAN and CPU_FAN, replacing thermal past, remounting pump, radiator and fan. Iv'e made sure all my fans are plugged in, and the pump is mounted correctly (not to loose not to tight) with arctic silver 5. The radiator and pump are plugged in correctly according to the instructions. I don't know if I have received a dead cooler or I have damaged my motherboard while switching cases or fighting the H60. (I bought a new case as well)
Hope some one can help, would appreciate it very much. Here are all my specs
Case
Cooler Master HAF-932 advanced
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
Motherboard
ASUS M4A785TD-V EVO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131398
Processor I have the stock cooler, should probably try it eh?
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
Power Supply
CORSAIR CMPSU-750TX 750W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
Video Card
Radeon HD 5670 (Redwood)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150466
Ram
G.SKILL 2GB (2 x 1GB) 240-Pin DDR3 1600 (x2)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231185
Case
Motherboard
ASUS M4A785TD-V EVO
Power Supply
Video Card
Ram
