If you are having the same issue with other programs, it's worth a shot. my guess is that for some reason the shortcut you had on your taskbar was being seen as a different program then the version of IE you were launching before, hence why I suggested you try to unpin the original and pin the new one that shows up.COOL! does this work with any program?
