GTX 560 + GTX 560 = Better?
magn3z
I've got Nvidia GeForce GTX 560 Ti 1GB and I was planning to get another better graphics card with at least 2 GB but why should i? I heard that you can use two graphics card at once sooo ... Can I just buy another GTX 560 and just kinda ... "plug" it in? :D :rolleyes:
It depends, what motherboard and what power supply do you have?
Power supply: Coolermaster Silent Pro 850W Modular PSU
Motherboard: Asus P8P67 R3 Socket 1155 USB 3.0 Bluetooth 8 Channel Audio ATX Motherboard
No, your board only supports Crossfire which is ATI, you need a board that supports SLI. And if you use a 2 gb card with a 1 gb the 2 gb card will only use 1 gb, same goes with clock speeds if that makes sense.
well there is software sli, but the second slot is a x4, so it may not get the best performance, but that also depends on another factor i don't know of on this board.
So, if I want a better graphic card (2gb) I need a new motherboard?
If you want to SLI then you need an SLI compatible motherboard. If you just want a 2gb card then just buy a single 2gb 560. You can run any single card that you want in your system. JLuchinski was correct in his last post.
