2048Megabytes
The FX-6100 will do 3.9 under default turbo. The FX-6100 will overclock alot higher then 3.9ghz. But you are right about the wattage, but the 6100 doesnt use anywhere near the wattage the X8 does.
Wouldn't it be better to go with the AMD FX-4100 Zambezi Processor then? One could overclock it higher with less Watt consumption and heat. Does the FX-4100 processor easily overclock to 4.4 gigahertz?
