can you guys look at what i am thinking of buying and let me know what you think? Is this all good?
a few concerns - is the RAM compatible with the CPU? the cpu says Dual Channel DDR3-1066/1333 but the ram is 1600. I have no knowledge of OC, but may want the option later
Also, I already bought the PSU and GPU - is the psu enough for this unit?
this is right in line with my budget. the mobo is inexpensive, but is it good enough?
thanks!
case - $70
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
cpu and mobo - $400
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.797209
RAM - $45
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
GPU - $270
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127608&Tpk=msi gtx 560ti 2gb
PSU - $89
http://www.newegg.com/Product/Produ...-na&AID=10521304&PID=4169961&SID=60wtr6ez55vl
DVD Drive - $20
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
hard drive - $120
http://www.newegg.com/Product/Product.aspx?Item=N82E16822145533
internal card reader - $16
http://www.newegg.com/Product/Product.aspx?Item=N82E16820223109
thanks!
case - $70
cpu and mobo - $400
RAM - $45
GPU - $270
PSU - $89
DVD Drive - $20
hard drive - $120
