What Games Will My Desktop Run?
Jackiz kirey
I am building a gaming desktop and I want to know what games and how smoothly it will run.
Motherboard MSI 970A-G45 AMD 9 Series
CPU AMD Phenom II X6 1035T
Ram Corsair Vengeance 4gb DDR3
Video card Evga GeForce Gtx 550 ti 1gb
Will it run skyrim, battlefield 3, modern warfare 3, global agenda, left 4 dead 2, and other upcoming games? With what settings and what will the fps be?
Should run all your games fine on medium to high settings, maybe even a bit of ultra.
The games you listed actually run rather well even on lower end systems. You might not be able to run everything on ultra, but as Alien! Where? said, it will indeed run them.
Well BF3 isn't fond of low end systems, but the 550ti is a plenty capable gamer, that setup should play any game out for a nice little while
But have you built this already? or can you make some changes?
Didn't build it yet. Also, can my desktop run diablo 3, Starcraft 2, and dota 2?
I didn't list diablo and dota on the list so now I'm asking a dIfferent question. Can my desktop run diablo 3, Starcraft 2, and dota 2?
My fault then, but the answer is yes, your computer will be able to handle those games fine.
Would not suggest getting a Phenom II 1035 if your using it for gaming. Its only like 2.6ghz. You would be better off going with a Phenom II 960T or 970 or even a FX-6100.
How man ghz should I get and how many ghz are he ones u suggested?
ghz isn't everything, but 3 or more is normally good, but like the 6100 and that 960t use a different design or architecture for the cpu itself, and the 960t's design is more efficient but it has some limitations where the other does not.
Send me a link to one of those CPUs so I can buy them please.
they're pretty good, but an intel i5-2000 series would be better. And if you live near a microcenter you can get them a lot cheaper, both intel and amd chips there are cheaper and they have combo deals.
