The links for the hard drive and GPU aren't working.
That is a pretty good setup he has there. But I would go for 8GB of RAM instead, since it saves you $65, and you won't see any performance increase going to 16GB.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
Then that will allow you to upgrade to a quad core:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103995&Tpk=960t
Case
Motherboard
CPU
RAM/Memory
PSU
GPU
HDD
CD/DVD Burner and Reader
Thermal Paste/Compound
I put a lot of work in this list so you better buy itAlso, I picked that thermal compound because of good reviews. Tell me if you buy this setup.
I think I'm gonna go with this one, thanks a tonCase
Motherboard
CPU
RAM/Memory
PSU
GPU
HDD
Why would you post this? I said $600 for a reason -_-You forgot an OS.
To the OP; It's going to be hard to get a decent gaming rig for $600, but I'll give it a try. Here's something I though together;
CPU/MoBo- http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.839448
Memory- http://www.newegg.com/Product/Product.aspx?Item=N82E16820233141
GPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16814161384
Case- http://www.newegg.com/Product/Product.aspx?Item=N82E16811133180
HDD- http://www.newegg.com/Product/Product.aspx?Item=N82E16822145531
DVD/CD- http://www.newegg.com/Product/Product.aspx?Item=N82E16827136240
PSU- http://www.newegg.com/Product/Product.aspx?Item=N82E16817207018
Total=$708 (with mail-in rebates, Total=$668) <--probably the best setup for gaming for under $700. Oh, and trust me, that PSU will power this rig with ease, your only going to be pulling 200-300w max.
Oh that rig he/her posted did not have an OS, which is $100 by itself, so his/her rig would of been close to $700 anyway.
Why I suggested this rig,because I was giving another option for you. and you act like I though $800-1000 rig out there,lol,wow, slow down,take a look here befor you go all berserk on me.I posted a rig for $668, $68 over budget, but that $68 over budget gets you a waay better build. But anyways, im not here to argue or anything, just giving you a better rig for the price, GL, and TC.
If your buying from Newegg, you should be signed up for eblast specials.
With current special promos you could get something like this. Yes, it’s more than $600, but only by the cost of Windows 7. If you have an os, then it’s right at your mark. Not counting the rebates.
If you want to use the cpu gift card towards the build you’ll have to leave off a regularly priced item and buy it 4 days later. Using the gift card and another $35 in instant deals = $50 from $741(after shipping) = $691 with Windows 7 and before $30 in rebates. If you don’t need Windows it’s $611 before rebates.
AMD Phenom II X4 960T Zosma 3.0GHz Socket AM3 95W Quad-Core Desktop Processor HD96ZTWFGRBOX
GIGABYTE GA-970A-UD3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
SAPPHIRE 100314-3L Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card + Memeory
Antec NEO ECO 620C 620W Continuous Power ATX12V v2.3 / EPS12V 80 PLUS Certified Active PFC Power Supply
Samsung by Seagate Spinpoint F3 HD502HJ/ST500DM005 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
COOLER MASTER Elite 311 RC-311B-BWN1 Blue Steel / Plastic ATX Mid Tower Computer Case + Burner
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
There may be some wiggle room if you want a diff case. ^ That's a good one for the price and it needs another fan.
Here's one for $45.
http://www.newegg.com/Product/Produ...030912-Index-_-ComputerCases-_-11147108-L013B
You don't have to get 8gb memory. 4gb is enough if your trying to stay at $600.
Hopefully he didnt but anything yet, because I really don't understand how your build is better. Maybe you can explain it to me -Oh my cheese guys!Mine is better than that and he made up his mind.
