I know it's a really good looking case, and it's so shiny too.I could use that door as a mirror if I wanted to.
The Lexa S is decent, but I'd say the 300R and StormScout are better choices, but if you want a great looking case then the Lexa S is a good choice. I remember buying it 18 months ago and thinking it looked like a bit like some kind of spaceship.![]()
The Lexa S supports water cooling I think, but the 300R is probably definitely the better case. It has the better cable management features too which you mentioned. If I'm brutally honest, I only bought the Lexa S because it looked so epic.Raz3rD said:Yeah, the 300R doesnt look as awesome, but what I can do with it is awesome. Has real nice cable management and enough room for a full Liquid cooling loop, which I plan to do anyway
The Lexa S supports water cooling I think, but the 300R is probably definitely the better case. It has the better cable management features too which you mentioned. If I'm brutally honest, I only bought the Lexa S because it looked so epic.It's not a bad case, but not the best either.
Man, mine is so much better than that
in my dreams.
With your dual video card, you should tryout Crysis 2 at maxed setting![]()
If you're not using the DX11 patch and extra textures pack, it'd play the same as ME3. Crysis 2 is still DX9.
in my dreams.
You owned Crysis 2 game?
Looks amazing Machin! Great choice of colour scheme too!The red pipes and the red heatspreaders on the RAM go well with the black board and case.
God I hate you people. I'm so jealous. You guys have real computers with gpu's and all.
