justlikecartman
Hi I am trying to build a computer worth around £700, I want it to have an i5 sandybridge, i want this to be the best for gaming for the price i am paying, if anyone can help it would be appreciated
just speccing you one now hold on!![]()
See above!
hoping for a better graphics cardWhich bits don't you like? You can spend less on the hard drive, power supply and case as I said, you'll save quite a bit there.
The GTX 560 Ti is a fantastic card! I've used that particular MSI Twin Frozr II one, maxxes out Microsoft Flight Simulator X at 1920x1080 on ultra settings at a good 60-70 FPS. A GTX 570 can be had for £200 though, see here http://www.novatech.co.uk/products/...s/nvidiagtx570fermiseries/012-p3-1571-kr.html but to be honest, a 560 Ti would probably be all you need.
Maybe you can get the cheaper case and hard drive and then put more money into the graphics card? The Corsair Carbide 300R is also a great case, and cheap http://www.overclockers.co.uk/showproduct.php?prodid=CA-063-CS it's £54.
yeah its decent for mid level games, but hes not going to get 60 FPS on BF3 on ultra or anything, need a couple of 580s for that.
I agree with you, but a couple of 580s are way out of his budget. A single 580 is over £300, so two is going to be £600, and his whole budget is £700. I think a 570 would be more than enough for him though.afsc102938 said:hes not going to get 60 FPS on BF3 on ultra or anything, need a couple of 580s for that.
What screen have you got? What resolution do you want to play these games at? What settings? Up your budget to £800 and you may be able to get a single GTX 580, and that would be a great card to get. 2500K shoudldn't bottleneck it, so don't worry about that.justlikecartman said:im looking at playing all new games such as battlefield and also starwars plus manymore like sniperelite
