Post A Pic Of Your Pc Here :)
One question. Why would you want to remove hard drive rack? I mean, you can keep hard drive rack next to fan to keep it cool. The more cool the more lifetime.
He probably wants better cool airflow while intake which the cage might be blocking.
Could always have cooler CPU/GPU.
And it is, couldn't fit a 120mm in the 5.25 bays.
As i review your case and CPU cooler. It should keep CPU and GPU cool well. It is good airflow. Plus, overclock can cause CPU and GPU to getting hot. As well as RAM will getting hot.
Also CPU cooler should be exhaust direct to rear exhaust fan.
Yup, yup, only overclocking my CPU at the moment, and the temps are fine. And my cooler has a second fan exhausting out the back.
final for now. Going crazy though cause my cable management looks like crap. And one of the fan headers is bent. :/
I have seen way worse on here. But it is still horrid. 2 things I have to say. Seeing them colours on the cables just drives me apeshit crazy, and the power leads at the bottom needs to be tidied up somehow. They look like someone just tossed them in carelessly.
Here's mine-
scaled.php
Direct link: http://img856.imageshack.us/img856/6060/riginternal.jpg
Direct link: http://img841.imageshack.us/img841/1268/img0056uq.jpg
Looking at the single 2.5" HDD sadden's me, haha. I really need to tidy up the cables as well, looks pretty messy... May also change out the RAM for red Dominator DIMM's and a red LED strip in the bottom. :D Also plan on changing out the megaflow in the front for a more thin and black 200 mm fan. as well as the fans on the H100.
CM Strom Sniper tower?
Here's mine-
Why is the 8-pin CPU power cable hanging around like that? Didn't it reach from the PSU to the 8-pin from around the rubber gromets from the back of the case?
The black theme looks good to me, except there are too many cable that are seen. Is you H100 push-pull intake or throws out air?
