I wish I was joking - blue screen of death
nuketown
First my desktop breaks
Now my laptop too?
Ok, so I was watching a YouTube video and all was ok
And then all the lights went off, all the fans stopped spinning.
I waited for a few minutes, no restart.
Powered on.
Windows recommended 'start up repair'... And while start up repair was loading, windows froze and I was greeted with the BSoD.
Computer shut down.
Is there anything I can do without knowing any error codes? The display only shows for a split second...
Download BlueScreenView
No installation required.
Unzip downloaded file and double click on BlueScreenView.exe file to run the program.
When scanning is done, go Edit>Select All.
Go File>Save Selected Items, and save the report as BSOD.txt.
Open BSOD.txt in Notepad, copy all content, and paste it into your next reply.
Could also be memory/RAM. Try downloading Memtest86 and test your RAM for half a day or overnight to see if you get any errors.
I don't have enough time in the OS to do anything before it shuts... I'll try safe mode?
Thanks a lot John, your a genius.
I have 42 recorded dumps, here are the ones for today.
Cheers
Dump File : 052912-20607-01.dmp
Crash Time : 29/05/2012 5:22:24 PM
Bug Check String :
Bug Check Code : 0x00000124
Parameter 1 : 00000000`00000000
Parameter 2 : fffffa80`029f1038
Parameter 3 : 00000000`00000000
Parameter 4 : 00000000`00000000
Caused By Driver : hal.dll
Caused By Address : hal.dll+f64c
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+4a4f1c
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\052912-20607-01.dmp
Processors Count : 2
Major Version : 15
Minor Version : 7600
Dump File Size : 262,144
Dump File : 052912-19468-01.dmp
Crash Time : 29/05/2012 5:20:22 PM
Bug Check String :
Parameter 2 : fffffa80`028954b8
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+4a4f1c
File Description : NT Kernel & System
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.1.7600.16988 (win7_gdr.120401-1505)
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\052912-19468-01.dmp
Major Version : 15
Dump File : 052912-27206-01.dmp
Crash Time : 29/05/2012 3:06:43 PM
Bug Check String :
Parameter 2 : fffffa80`0289c4f8
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\052912-27206-01.dmp
Major Version : 15
Dump File : 052912-20623-01.dmp
Crash Time : 29/05/2012 3:05:26 PM
Bug Check String :
Parameter 2 : fffffa80`028998f8
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\052912-20623-01.dmp
Major Version : 15
Dump File : 052912-18844-01.dmp
Crash Time : 29/05/2012 7:10:43 AM
Bug Check String :
Parameter 2 : fffffa80`02a126a8
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\052912-18844-01.dmp
Major Version : 15
Dump File : 052912-19640-01.dmp
Crash Time : 29/05/2012 6:57:27 AM
Bug Check String :
Parameter 2 : fffffa80`029f88f8
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\052912-19640-01.dmp
Major Version : 15
Dump File : 052912-20841-01.dmp
Crash Time : 29/05/2012 6:48:50 AM
Bug Check String : CRITICAL_OBJECT_TERMINATION
Bug Check Code : 0x000000f4
Parameter 1 : 00000000`00000003
Parameter 2 : fffffa80`037a6b30
Parameter 3 : fffffa80`037a6e10
Parameter 4 : fffff800`02d89720
Caused By Address : ntoskrnl.exe+70040
Processor : x64
Crash Address : ntoskrnl.exe+70040
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\052912-20841-01.dmp
Major Version : 15
Dump File Size : 274,512
That sucks... Im new to Windows so the only thing i worry about is Kernel Attacks! (My first build will be only the second windows in my lifetime!!)
Bugcheck 124 refers to a hardware issue. Any new hardware lately? Can you list your system specs?
With this type of bluescreen nothing is cut and dried. The 2 things you should do first are testing the memory and the hard drive for errors. If both come back clean then I'm not sure. Has there been any new hardware added to it lately? Do you have any usb devices attached?
