I do use the command line but it is a choice, there is a GUI tool for just about anything including finding drivers in Ubuntu. You will notice that in the Linux community you will find some of there older school Linux users that only use command lines, I remember when I started on 8.04 when I would ask a question on line it was always a command.
Not to mention system resources, currently surfing the web, listening to music and watching movies via HDMI cable from laptop to tv and using less resources the Windows 7 does at idle.
The OP seems to be having browser or internet problems. Couple with that the lack of certain specific programs he was used to having in his old OS which may or may not have analogs in the new one (no one mentioned trying Thinderbird as an Outlook express replacement, for example).
I prefer Outlook Express to Thunderbird.
Only reason for this is windows doesn't over-commit ram, nothing more.
<ahem>
That is fine but when using some heavier open source music production software that will not even give me all the features due to MS ram hungry were as when running on a Linux box I have full features.
As far as the OP, i would be using windows XP if it was still supported (hardly any support left these days) and it had some of the things I needed like DirectX and hyperthreading (that was a 7 addition right?)
Xp to me was clean and streamlined. 7 just seems like it's that rich kid with all the cool toys and nice clothes. I don't need that, I just want the basics. I'm used to OS's that take up 2.5 Gb's on install, including a office suite and any other day to day app I need, not 17-20gb's.
Just my 2 cents.
Again not exactly true. DirectX has been around since 1995 meaning almost all Windows versions can support it. Also hyperthreading is done on both the OS and the hardware, and has been around since 2002 making it well in the realms of XP.
Windows 7 has some significant changes, particularly with SSDs, memory management, driver support, network optimisation... the list goes on.
By far the best OS available if you want out of the box support for a large range of OEM hardware.
Although I like Linux (especially Nyxcharon's distro, which is very good), I can't help agreeing with the fact that Windows 7 just works how an OS should. I mean, whenever I try to use Linux, I end up spending more time installing programs than I actually do using them. On Windows, you can focus more on what you're actually trying to accomplish. Yes, it uses more system resources, but with 2GB of RAM and a decent processor, it makes no difference to me.Again not exactly true. DirectX has been around since 1995 meaning almost all Windows versions can support it. Also hyperthreading is done on both the OS and the hardware, and has been around since 2002 making it well in the realms of XP.
...(i installed it because visual studio 2010 won't run on xp)...
