NyxCharon
Currently running a
Intel E8400 C2D @ 3.5Ghz
ASUS P5G41T-M LX Plus Mobo
This is paired with a ASUS GTX560 and 4GB DDR3 Ram.
I can game fine (Most games on ultra), but I do a lot of VM work, and the CPU just can't handle multiple ones at a time that well.
I don't have a lot of money to spend and won't be able to do a signifigant upgrade until later next year. In the meantime I was considering getting a
AMD Athlon II x4 631 and this mobo:
ASRock A55 PRO3 FM1 AMD A55
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157278
According to CPU benchmark, it's about a double in the performance area, or at least it seems. I'm a Intel fanboy, so I know nothing about AMD CPU's. Is it worth the upgrade? Also, how well does this thing overclock, if at all?
Thanks.
Thanks.
