Would not touch those korean ones... way too cheap for a 1440. I'd either go for the 120hz 1080 or a real 1440, but that'd cost you a lot. I wish I could get one of those.
take a good 1440...
you need that resolution to make your 27" in games detailed
A good one is like $900 legit
So good Sammy 27" 1080p@120Hz or
Some Korean 27" 1440p@60Hz
give links, I just had geography exam.
It says that in china and Korea products are made by unshooled people for a low pay. But doesn't matter xD
Ok guys
Probably looking at a 27" monitor.
I'm pretty much stuck between two - 1080p@120Hz
Or 1440p@60Hz
For the 1440p I was considering the Korean ones for ~$300; but are these 'B' grade monitors any good? And warranty?
Thanks a lot
What is your system specs? CPU? Video card? RAM? It is important so that we can tell whether to getting 1080p or 1440p monitor.
if its going to be 27 inch, get a 1440 res, if its less, stick with 1080, just too much area for 1080 to look right on a 27 inch display imo
What about 1080 @ 120Hzyeah, really take a 1440 res for 27" or higher!
The details and video quality will be like shit with an 1080p...
120hz is the refresh rate...
You really need a 1440 for a nice detail on a 27"
Maybe Korea's the option!
Should be ok i'm sure
Either 670 or 7970 (just can't decide!)
8 GB RAM @ 1333MHz
i5 3570k Overclocked (hopefully to 4GHz)
