This is so hard! Monitors?
nuketown
Ok guys
Probably looking at a 27" monitor.
I'm pretty much stuck between two - 1080p@120Hz
Or 1440p@60Hz
For the 1440p I was considering the Korean ones for ~$300; but are these 'B' grade monitors any good? And warranty?
Thanks a lot
Would not touch those korean ones... way too cheap for a 1440. I'd either go for the 120hz 1080 or a real 1440, but that'd cost you a lot. I wish I could get one of those.
Ok guys
Or 1440p@60Hz
Thanks a lot
What is your system specs? CPU? Video card? RAM? It is important so that we can tell whether to getting 1080p or 1440p monitor.
if its going to be 27 inch, get a 1440 res, if its less, stick with 1080, just too much area for 1080 to look right on a 27 inch display imo
After reading reviews, it actually seems ok... but that ebay page just looks sketchy to me. If it works good, hell I might consider getting one.
Should be ok i'm sure
Either 670 or 7970 (just can't decide!)
8 GB RAM @ 1333MHz
i5 3570k Overclocked (hopefully to 4GHz)
You might play Crysis 2 at 1440p fine but you will notice a little lag.
yeah, really take a 1440 res for 27" or higher!
The details and video quality will be like shit with an 1080p...
That is not true. 1080p would look good at 27" monitor also. I have blu ray via HDMI at home and it look nice than watching DVD.
He's not talking about videos hes talking about gaming. Also tv's and monitors are completely different. I agree with smile if OP is going 27" he should be looking at higher 1080.
