Looking for a new mobo
bully818
I am thinking about getting the "ASRock Z77 Extreme6" or the "asus p8z77-v pro".
Right now i have the asus p8p67 le . ( dislike that board a lot)
and i7 2600k, 8gb 1600 memory, gtx 570.
What do you guys think about those two boards as an upgrade?
Both are really nice boards. Can I ask why you didn't like the P8P67?
Out of the two you said I would pick the Asus board. Only because I think Asus as a whole is a better brand but really it's up to you.
You might also want to look at some Gigabyte boards, another great brand. Something like this. That's about the same price of the other boards you picked out :).
Well its the LE version. It takes away freedom from OCing and i also feel like i can get better temps with my setup. Thanks for the input
Both are good, but I'd say the Gigabyte GA-Z77X-UD3H is also a great board and I'd choose that over the ASRock and the ASUS. Here it is on Newegg http://www.newegg.com/Product/Product.aspx?Item=N82E16813128544&Tpk=ga-z77x-ud3h
You may have to update the BIOS on Z77 boards before you can use your 2600K in one.
