You will get a incredibly small performance boost over your 3570k's Intel HD 4000, if any. You wont be getting to play any more games than your HD 4000 either. Also, its not even a good deal anyways, you actually are overpaying by $5. If you want pretty reasonable gaming performance for $100 and under: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127606
or, not as reliable, but fine, and good gaming performance: http://www.geeks.com/details.asp?InvtId=ENGTX460-PCIE-1024-CO
http://www.geeks.com/details.asp?invtid=7120468000G-2-BULK $60
Not the best idea to get this card, but its fine.
http://www.ebay.com/itm/EVGA-GeForc...eo_TV_Cards&hash=item25725c9009#ht_2555wt_161
AWESOME price for this card, not the best by any means, but it willl play many games.
You don't know what you are talking about.~snip~
~snip~
I am not using it for anything at this moment... just trying to add something to my first build desktop. By the way I want to have a decent computer which I can listen to music, watch video online..
I just spent over 4 weeks, 24/7 Folding with a GTX 460 overclocked to the max and I did not have a single problem with it.
Folding makes a gpu work harder than gaming does.
I believe those cards are directly from nvidia. So Nvidia is a not reliable brand? (the one you recommended)The brand is not as realiable.
So, you are saying that Asus makes a crappy gpu?The brand is not as realiable. Also, just stck with the hd 4000 if on a budget, or get a 9800 GT for some nice performance for $40. Also, motherboard and PSU?
I didn't find many complaints in a Google.
The model # indicates it's an Asus.
Have you ever owned one or what is the source of your info?
