Will this work?
angush
This computer will be mostly for gaming with a bit of photoshop, video editing and overall gfx. I'm wanting it to play game like BF3 (ultra settings or close to it), Skyrim (ultra settings) and next-gen games. This rig also needs to be future proof in terms of being able to play those next-gen games but i assume that will need an I7 with it's hyper-threading capabilities. There will also be moderate over-clocking and hopefully i will watercool this rig. Here are the components:
Windows Professional ( I am only getting this as i may consider upgrading to 32gb in the future; i will also be getting the OEM version seeing as i am a system builder.)
Corsair Special White Edition Graphite Series 600T Mid-Tower Gaming Case
Sony AD-7280S-0B 24x Internal SATA DVD Multi Writer Black
I5-3570k (Mainly for the over-clocking and the good price drop over the I7-3770k)
Corsair Hydro Series H100 Extreme Performance CPU Cooler
Corsair Force Series 3 120GB Solid State Drive
Western Digital Caviar Black 1 TB 7200 RPM Internal Hard Disk Drive
EVGA GeF GTX 670 2GB GDDR5 Graphic Card
Corsair Vengeance 16GB (8x2) 1600MHz CL10 DDR3
TP-Link TL-WN851N Wireless N PCI Adapter
Asus Sabertooth Z77 Motherboard
Corsair Enthusiast Series Modular TX750M PC Power Supply
Asus 24-inch VH242H Wide Gaming LCD TFT Monitor
BTW, I love Corsair...
Also are there any ways to make this cheaper without sacrificing processing power?
Looks to be a very nice build.
I would strongly recommend you don't get the H100 Cooler though,I bought one a few weeks back and the Pump was very noisy,And after reading a lot of reviews it appears this is a common issue,even some people receiving RMA replacements that are just as bad or more noisy.
Don't get me wrong,It cools very well but for the price the quality just is not there and for Corsair its pretty disappointing especially for the price.
I would get a decent air cooler instead.
Noctua NH-D14 SE2011
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608024
Nice build you've put together!
Yes it will work.
As Neva said, change the CPU cooler to the one he linked.
I'd also get a Gigabyte motherboard. They're more reliable and Gigabyte have better customer support if something does go wrong.
I'd recommend the GA-Z77X-UD3H or the GA-Z77X-UD5H.
I would get the Gigabyte GA-Z77X-UD5H like S3 said, or G1 Sniper 3 (will need new case), or a Intel z77 extreme, if you want a enthusiast boards. The vengance memory is high, and the noctua is huge, and I bet you is as loud as a H100. Stick with a h100. Or get shorter memory.
I would get the UD3H if you do not need the few extras that the UD5H comes with.
^ This. The UD3H is a very good board and the UD5H doesn't have a awful lot to offer over it.
The Crucial M4 and SanDisk Extreme SSDs are faster than the Force 3 - see the M4 and F3 comparison here http://www.anandtech.com/bench/Product/425?vs=400 the M4 and the SanDisk are also very stable drives. I'd get the SanDisk Extreme 120GB if you can as it's even faster than the M4 and usually cheaper than both the M4 and the F3 too.
REVISION:
Noctua DH-14
SanDisk 120GB Extreme SATA III 6Gb/s 2.5in Internal Solid State Drive
CorsairLP Vengeance 16GB 1600MHz CL9 DDR3 Four Module Kit
Looks good to me, but you can save money by going for either a GA-Z77X-UD3H or even a GA-Z77X-UD5H over the Sabertooth board.
He asked why the board isn't very good vista, so here is why: Asus's support has really gone down hill the few years. You know, like you get a broken board, they might not take it back, etc. And, there board's quality has really gone down hill, to. So, paired together, not good. Gigabyte is a great brand, so is intel's motherboards. Sounds like you want a enthusiast board, so get one one of these: http://www.newegg.com/Product/Product.aspx?Item=N82E16813121605
