CrazyHV8000
K guys, here is a snapshot release from the next version 2.2!
Not all the problems are fixed, but thats why we release only a snapshot.
The benchmark will now have 1 Test in case of 2, the passes are built in different ways and different quantities of threads.
Cpu Breaker: 16threaded with 1 very heavy calculation
8-threaded: 8threaded with much easy calculations
4-threaded: 4threaded with 4 big calculations
Xtreme Pass: 32threaded with 1 heavy and 3 other easy calculations (PC crashed when I did 46threaded, so I don't know that it works on dual core cpu's or 1core)
The times are measured in seconds.
Your points are Visible in the right corner under in the app. (higher the better)
Under the 4 passes an average from the 4 is shown.
The benchmark last longer and is a bit more stable. The 4threaded is not yet fully fixed, but that doesn't matter much in the points.
You can download the app here:
http://www.2shared.com/file/L07kppJZ/Smiles_App.html
Preview (me):
The scores will be an appart subject in the scoreboard.
SmileMan & Vistakid10
You might want to change on OP at first pages?
