Virssagòn
Black Hole V2
By SmileMan & Spirit
Hey guys,
here is the next version of Black hole!
It will be stable for both companies: Intel and AMD.
It's a multithreaded and singlethreaded benchmark, so we can see how good your cpu is per core and how well when it uses all of it's cores!
Some Information:
Multithreaded
- 3 passes and one warming up round
- 1st pass: calculating with floating point maths, this is 8threaded
- 2nd pass: integer maths, 8threaded
- 3rd pass: Xtreme pass, 32threaded (integer maths)
Singlethreaded
- 2 passes
- 1st pass: integer maths
- 2nd pass: floating point maths
64x BIT ONLY!
The tests will last at least 3 minutes to run the 2.
It can be unresponsible for a while, just let it do his thing then.
All other programs must be closed for best results.
The results you can post here.
I'll post the scores in one ranking table.
You must run the 2 tests for getting the final score!
The higher the scores, the better!
Installing the benchmark:
Not really difficult:
just download the zip file from here
extract the exe
And run the 2 tests
Preview:
Scores:
AWARDS OF BLACK HOLE V2! (sorry that you had to wait)
Here is an overview of all the tests from Black Hole v2:
The top 10 and their grandpa:
Winners of the top 10 award:
1. KasperL - 3930K @ 4.3
2. Yachu - 2600K @ 4.5
3. Jiniix - 2600K @ 4.8
4. LaquerHead - 3700K @ 4.9
5. SmileMan - 2600K @ 4.7
6. Wolfeking - 2600K @ 4.7
7. Tech Savvy - 2550K @ 4.5
8. Jiniix - 2500K @ 4.8
9. salvage-this - 3570K @ 4.7
10. SmileMan - 3700 @ stock
congratz!!
The 3rd place go to!
Jiniix - i7 2600K @ 4.8 - 1,210 pts
On the second place!
Yachu - i7 2600K @ 4.5 - 1,254 pts
And the winner is!!!
KasperL - i7 3930K @ 4.3, 1,323 pts
At our last place!
Spirit - Athlon 64 3700+
The best Intel in this bench!
KasperL - 3930K @ 4.2
The AMD winner is!
StrangleHold - FX-8150 @ 4.5
Then we have our guy with his high oc!
LaquerHead - 3770K @ 4.9
And the tester with most balls is!
Jiniix
Thank you all for testing and congrtz with your awards!!!!
Smile & Spirit
Hey guys,
Some Information:
Multithreaded
Singlethreaded
- 2 passes
64x BIT ONLY!
extract the exe
And run the 2 tests
Preview:
Scores:
congratz!!
At our last place!
The AMD winner is!
Jiniix
Smile & Spirit
