Ocean Spray
6850 and yes. My monitor has a VGA cable and so I have it connected to the MoBo and not the video cards DVI port. What are the BIOS settings needed to disable the MoBo display and or is it that I need a DVI-VGA adapter?
Do you have the 6 pin PCI express power connector going to the video card?
If the video card only has dvi and your monitor cable is only vga then yes you need to dvi to vga converter. Most cards already have one of these in the box, check to make sure yours didn't come with it.
