Never Built a Computer Before.
salvucci91
I'm about to go to school for animation and game design, and will absolutely require a computer. I also have always been an avid gamer, and since a young age have wanted to break into computer gaming.
Since I've already dropped all of this money on school, I might as well buy high-end, to prolong inevitable upgrades that will be required in the future. I want to primarily build a gaming laptop, that could handle new games on high settings, and will have ample space and processing power.
I know enough to buy from NewEgg, and have read their guide on buying a notebook/laptop. But other than that, I'm pretty clueless.
I would greatly appreciate input on what you guys think I should buy all together, what is worth shelling out the cash for, etc.
A thousand thank-you's !!
What he's trying to say is that it is impossible to build a laptop from newegg. You can customize a couple, but that's about it. If you want to have great graphics, go for a desktop.
Hmm. At one point, I was thinking that I should purchase an AlienWare. But then I had a few people telling me that AW sucks, and that I should buy from NewEgg.
If I were to purchase a pre-built laptop, which company would you guys recommend??
I personally recommend Sager. I've never purchased from them, but I do have a friend that got a pretty decent laptop out of them. Was able to use it for a bit, it seems alright.
What's your budget?
If you want a gaming machine, I'd go with this one
http://www.newegg.com/Product/Product.aspx?Item=N82E16834230403
A higher power machine would be this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16834230407
If you have even more cash to spend, you could look into Falcon Northwest.
http://www.falcon-nw.com/laptops
