CrazyHV8000
I just got my 7770 XFX and it doing 3D MARK VANTAGE well at P13318
I'm going post picture of it soon.
Nice, any other place you could put that add-on card? Might be blocking the intake a little bit.
he can move it directly on top of the card. It is currently in 1 of 2 unblocked x1 ports. And that would help. He could put it in the lower x4 slot if he had a ivybridge processor.
BS. Read the specs of the board.
correction: seems it does work like that which is retarded as the x4 on the UD5H requires ivybridge. You would think they could make something uniform through the series, but seems not. Either way, you are in danger with blocking the air port like that. 10MM is not a lot of space.
You've still got your original i3 sticker on the case!
Huh? I think the fact that you still have the original Core i3 Inside sticker on the case makes it kind of obvious it originally had another i3 before your current one.Hahaha. What making my original i3 famous?![]()
installed it, seems to help with Secondlife the way i expected, im pleased.
