New Build - a couple questions
Yeah, that 780i can do tri-SLI at x16/x16/x16, and yes quad-SLI is available and has been for a few years now.
SLI never used to be able to support more than one monitor, I have a feeling it can now though.
Thank you guys!
So I did some thorough research and came up with a few updates:
CPU:
Intel Core i7-3770K BX80667i73770K 8MB L3 Cache, 3.50GHz (3.90GHz Max Turbo), LGA 1155, 77W, Fan, Unlocked
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2372989&Sku=I69-3770K
A few factors affected this change of mind. Mainly, it's unlocked and 22nm.
MB:
GIGABYTE GA-Z77X-UD3H LGA 1155 Z77 1600MHz DDR3
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2276156&Sku=G452-2363
I know ASUS is better, but I've been using GB forever and no complaints so far.
GPU:
GIGABYTE GV-N66TWF2-2GD GeForce GTX 660 Ti 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125441
RAM:
Debating between two of the same price and timing:
a) G.SKILL Ares
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231549
b) Corsair Vengeance
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233239
PSU:
CORSAIR HX Series HX750 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
Links from different websites due to the better prices.
