spirit Moderator Staff member Sep 12, 2012 #21 Yeah, that 780i can do tri-SLI at x16/x16/x16, and yes quad-SLI is available and has been for a few years now. SLI never used to be able to support more than one monitor, I have a feeling it can now though.
Benny Boy Active Member Sep 12, 2012 #22 http://www.newegg.com/Product/Combo...-EMC-091212-Index-_-Combo-_-Combo1068638-LC2C
butter New Member Sep 12, 2012 #23 hm, okay, shouldn't be an issue, as SLI only needed for games, and they are single screen anyways. I hope it won't be a pain in the neck to switch between SLI/non-SLI (no hardware tinkering involved!) and here's a nice article that relieved me from worrying about x16 and x8. Apparently it differs by decimals. http://www.tomshardware.com/reviews/amd-crossfire-nvidia-sli-multi-gpu,2678-5.html
butter New Member Sep 12, 2012 #24 Benny Boy said: http://www.newegg.com/Product/Combo...-EMC-091212-Index-_-Combo-_-Combo1068638-LC2C Click to expand... a drop from i7 to i5.. and RAM latency is 9, I was hoping for 7 or at most 8.. but it's definitely a great deal! half the price!! :good: Thanks!
butter New Member Sep 12, 2012 #25 Thank you guys! So I did some thorough research and came up with a few updates: CPU: Intel Core i7-3770K BX80667i73770K 8MB L3 Cache, 3.50GHz (3.90GHz Max Turbo), LGA 1155, 77W, Fan, Unlocked http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2372989&Sku=I69-3770K A few factors affected this change of mind. Mainly, it's unlocked and 22nm. MB: GIGABYTE GA-Z77X-UD3H LGA 1155 Z77 1600MHz DDR3 http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2276156&Sku=G452-2363 I know ASUS is better, but I've been using GB forever and no complaints so far. GPU: GIGABYTE GV-N66TWF2-2GD GeForce GTX 660 Ti 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI http://www.newegg.com/Product/Product.aspx?Item=N82E16814125441 RAM: Debating between two of the same price and timing: a) G.SKILL Ares http://www.newegg.com/Product/Product.aspx?Item=N82E16820231549 b) Corsair Vengeance http://www.newegg.com/Product/Product.aspx?Item=N82E16820233239 PSU: CORSAIR HX Series HX750 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010 Links from different websites due to the better prices.
Benny Boy Active Member Sep 13, 2012 #26 http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1049918 Plus gift card. http://www.newegg.com/Product/Produ...SubCategory=48&SortField=0&PageSize=10&page=1
butter New Member Sep 13, 2012 #27 Benny Boy said: http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1049918 Plus gift card. http://www.newegg.com/Product/Produ...SubCategory=48&SortField=0&PageSize=10&page=1 Click to expand... Nice, definitely a 20$ cut. Thank you.
