Just built my first computer, and it wont turn on?
alexjb
If after reinstalling windows and the motherboard cd still has issues installing the drivers, then let me know. The drivers from MSI's website should be EXE files and all you do is run them and it automatically installs driver and any needed software.
thanks john :) I hope it works, I will let you know :)
spirit
Moderator
For the time being select Ask Me Later, you can update it all once you've got your drivers installed and working.
wolfeking
banned
use whatever setting you want. I personally always use remind me later and set it to get no updates and check for no updates.
alexjb
Okay windows has installed and the screen is all loaded up :) what shall I do now ? Insert the MSI disk or the memory stick? or do something else?
Thanks
spirit
Moderator
Copy the files off the memory stick and install your drivers. John said they should be EXE files, so just click on them to install, as if you were installing any other program.
spirit
Moderator
Yeah the file extensions are hidden by the default so it will only appear to be called 'setup'. Just click on the file to launch the setup and it should be fine.
alexjb
what is going on? :(
