Update your .NET Framework.
By the way I used to own an i5 760 before I got my 2500K, awesome processor!![]()
Yeah, 105c at 4.4 is WAY to high.
What kind of temps do you have now?
The thing about 3570k VS 2500k temps is dumb. Those rumors only circulated from extreme benchers. For daily rigs, a 3570k only runs ever so slightly warmer, only a couple degrees on the same cooler/overclock/voltage.
How do you figure that. This is a 8120 at 4.5. Just 100 mhz faster then that 3570 and beats its with a 688 in multi.
I never overclocked my 760, so I can't comment on overclocking, but at stock it was fast. I bought it at the end of the December 2010 though, about two weeks or so before Sandy Bridge replaced it. I remember being very annoyed at myself! To be honest I can't really tell the difference between the 760 and the 2500K, other than the fact the 2500K is overclocked so maybe it is faster at rendering.Yeah in the real world, Lynnfield processors are not much behind sandy bridge at all. They just run a lot hotter and don't overclock as well typically. They pretty much all can get to 4ghz though. But clock for clock, they are not that much slower at all. I paid $70 for this I5 760, a steal for the performance it offers. Right now running 4ghz at 1.28v, so this must be a decent clocker. I'll probably be able to get atleast 4.4-4.5ghz for this benchmark if I can get it to work.
Nice scores over there!
Stranglehold was right, the FX scores a bit higher at the same clock speed in multithreaded.
What were your 2500K temps at 4.5Ghz with IBT? I'm running around 78/89/82/82. Of course, my processor isn't the best, but still. It does run hot even with a good cooling setup.
3570k (3.4ghz) is the blue line VS 8150 (3.5ghz) the black line-
VS 8320 (3.5ghz)
VS 8350 (4.0ghz)
Yeah, but I'm not really willing to invest more than I have into cooling already.
It's mostly ashame that it throttles at 70c. If it was 100c like normal I'd be able to get a lot higher, maybe even to 4.2ghz.
hehe, what cooler do you have?
Just place your pc outside and try again xD
I bet it would cool better then, if it's -8°C outside (at night).
